lemstreak so you have the saxonette/spartomette over there, eh?
http://www.reelight.com very interesting. since the power requirements of a system designed for lighting LED's are low, the designer(s) have an all-in-one daylight running kit, also for night ? which uses magnets fixed to the spokes (6 rare earth NeoDym) and a pick-up coil mounted on either the front or back forks. Solves the SA weight issue! And the generator resistance issues.
I think I'm looking for a hub generator otherwise, the DH-3N30.
Update, the DH-3N80, better bearings and seals.
http://stores.ebay.de/taylor-wheels/26- ... 581&_pgn=2
choosing from this list... thinking the third one... 50EUR... The Rigida might be a stronger rim design? I like you am concerned about stopping power, dual brakes sound like a good idea. The V brakes seem to be working well.
http://www.ebay.de/itm/26-Zoll-Laufrad- ... 5d38c76ffe
update:
http://www.ebay.de/itm/26-Zoll-Fahrrad- ... 5d35fd4975 due to the better bearing system and seals, the DH-3N80 dynamo rates higher.
