Spartmet für die adaptive Federgabel (Sonderausführung)
watchtech
Re: Spartmet für die adaptive Federgabel (Sonderausführung)
Beitrag von watchtech »
Unfortunately, the negative answer came to me from them :'( . I'm sorry.
Hello,
But you have sent your mail to Sturmey-Archer/Sunrace. We have nothing to do with a Spartamet. Why don’t you ask Spartamet?
Best regards / Met vriendelijke groet,
Ebert van Vliet
Sunrace Sturmey-Archer
tel. +31 206090221
fax +31 206090211
http://www.sturmey-archer.com
http://www.sturmey-archerheritage.com
http://www.sunrace.com
Hi There,
So you are looking for a clamp to attach the brake anchor. We have got those in our program but they only fit normal size forks.
Suspension forks ( the lower legs of them) have a larger diameter compared to normal road forks. So the clamps we have will not fit a suspension fork.
Kind regards,
Sturmey Archer / SunRace
Tel: +31 (0)20 - 6090221
E-mail: info@sunrace.nl
Hallo Watchtech,
such a part can build everybody who works with metals.
:smile: - Dieter
bin kein großer Künstler...
watchtech
This is a nice drawing. Thanks Dieter-K . However, there is one a little problem . İf it is ( drawing clamp) used... Anchor does not fit into the fork. and pressure will occur ???
Problem not your clamp. problem thick fork tube *THUMBS UP*
Hi
As it seems the Original front wheel off the spartamet is the problem.
I would say lose the Original front wiel. And change it for a normal 1.Like from a normal bike..http://www.marktplaats.nl/a/fietsen-en- ... ousPage=lr This is just a example
Than go for the front brake like from a normal bike.
Like this 1
http://www.amazon.com/SRAM-Apex-Front-B ... 11&sr=1-14 :redface:
watchtech hat geschrieben:Anchor does not fit into the fork. and pressure will occur ???
Yes, I understand. Pressure will occur, sorry.
Nach meiner Skizze passt es leider nicht, weil der Bremsanker nicht an dem dicken Rohr der Gabel vorbei passt.
Die Bremse würde verkanten.
watchtech
Dieter-K hat geschrieben:
Yes Dieter-K, Maybe my design could be improved . A similar drawing (design) may be better. *THUMBS UP*
Hallo Watchtech,
da ich kein Bild von vorne hatte, habe ich mir selber eins gebaut.
Auf meinem Bild ist die Überlappung nicht groß.
Wenn man den Hebelarm der Bremse etwas verbiegt und den oberen Versatz begradigt, könnte es passen.
Aber eventuell ist die Realität anders als mein gebautes Bild.
watchtech
Hello tnt-dennis,
Your montage is very nice. Thank you for labor @}->-- . Anchor rod to bend, not a problem. But what is the anchor material? This is very important. If it is only iron material, no problem. İf it is cast iron materials, this is very easy breakable. I tried to bend very little before. But jammed the brake pads. Therefore, this design (my design) much more compatible , brake pads runs smoothly. :smile:
Hello Watchtech,
I don´t think it´s cast iron. I would say it´s drop-forged steel.
Blechbearbeitung durch Stanzen und Pressen...
So stellt man Teile wie die Bremsankerplatte her:
http://www.youtube.com/watch?v=sWL7wGEW-0A
:wink: - Dieter
