broken rear wheels suche etc
ndrscons
Beitrag von ndrscons »
Hi,
I have an offer from a welder (schweißer) to TIG-weld broken wheels. So we are going to test with a chipped wheel.
From the forum members: We also just need the hub component of the wheel (the centre part) to design and build a three-wheel version with carrying capacity in the back. The hub can be converted into a belt-drive without welding, it is believed. So does someone have a damaged wheel to contribute?
thanks.
Re: broken rear wheels suche etc
Beitrag von Kolbenfresser »
Look at This
http://kleinanzeigen.ebay.de/anzeigen/s ... 7-217-1019
it is with Chain.
ndrscons
Thanks.
The photos will be saved, for the mechanic and bike engineer.
Had seen photos of a green one, on kijiji auch..
the photos were not so clear though as in the yellow one.
Yes, so the wish is to have cargo area. These 'OEM' saxonette drei-rad have no cargo space between the wheels. Thanks again though for the photos (link).
The position from the engine isn`t good for Cargo, change the exhaust and take the engine on the left side.
Ok, so gut ist mein Englisch nicht.
Ich würde den Motor nach links unten setzen, so das die eigentliche Abtriebswelle in Höhe der Hinterachse liegt, dann passt auch die Kiste drauf. Auf den Bildern ist die Technik jedoch gut zu sehen, vorallem auch die Integration der Schaltung. Durch ändern der Kettenführung wäre eine Schaltung denkbar die auch den Motorbetrieb beeinflusst.
ndrscons
I get the english instructions! answer in any language is okay. *THUMBS UP*
